Factory Stereo Question
I'd either get new factory subs, or get a different amp to go with your new aftermarket speakers.
You can easily replace the headunit on a non-Bose 4th-gen f-body with a simple mounting plate and cheap wire adapter. Technically you can make the mounting plate and you can tap into the wires directly, but a harness is neater.
Also, replacing the speakers can be done while keeping the stock amp.
The stock rear seat speakers are DVC subs (Dual Voice Coil). That is why there are four wires. Two wires per voice coil.
You can find plenty more info like this in the Stereo & Electronics section by reading the stickies and searching. If you can't find your answer, then start a new thread in that section.
