Moonsoon Headunit install
Old Dec 11, 2007 | 04:32 PM
01riceeater's Avatar
Default Moonsoon Headunit install
Hey guys i just bought a moonsoon headunit off a member here and am hoping to replace my crappy tape deck in my 01 camaro with it as soon as it gets here. Whats the best way for me to go about doing that? Also, hes not sure if the theftlock is deactivated, so is there some universal code i can use so my cars electronics dont get all screwed up? thanks
Old Dec 11, 2007 | 05:02 PM
KEE AUDIO's Avatar
Installation is very easy. Pop the front bezel off and you will find 4 screws (7 or 8mm drive bit I think), 2 on each side holding the stock radio in place. Once you undo the screws the radio will slide out. Unhook the harness on the rear hook the new one up and reverse the process. Hope this helps!!
Old Dec 11, 2007 | 06:15 PM
Thanks for the advice man!
Old Dec 11, 2007 | 06:20 PM
01ssreda4's Avatar
GM uses 7mm, don't lose that socket, you gonna need it again. or 9/32nds i believe will work too.
Old Dec 11, 2007 | 07:21 PM
KEE AUDIO's Avatar
7mm it is! I couldn't remember off hand but I knew it was one of the 2. 9/32's does also work.
Old Dec 14, 2007 | 07:36 AM
thanks a lot fellas, im about to go try this!
Old Dec 14, 2007 | 12:38 PM
its definately a 7mm. got that sucker in!
