Taillight Mod
Old Dec 13, 2007 | 03:49 PM
mermel's Avatar
Default Taillight Mod
I saw a 1985 Chevy Caprice with this once. The pic is small because it's someone's avatar on ThirdGen.org
I want to do this to my 01 T/A. Anyone know how?
Old Dec 13, 2007 | 04:23 PM
ghettocruiser's Avatar
Its commonly known as the "sequential turn signal mod". I think you can get a module, and you have to change the outermost socket...but that might be all there is to it. I dont know for sure...
Might turn something up if you google seq. turn signal mod.
Here is a site off the cuff...although not showing any support for f-bodies, it might be a good place to start.
http://www.sequentialtaillights.com/
And another site that has it listed..but looks like you have to join the site.
http://www.importmodifications.com/chevroletcamaro.html
J.
Old Dec 13, 2007 | 07:10 PM
87formy's Avatar
IIRC the guy you got the avatar from sells them. He might be able to help you out. I might have seen kits on ebay too.
Old Dec 14, 2007 | 07:05 AM
WhiteBird00's Avatar
Ungrounded Moderator
Have a look on Brent Franker's site. Brent is well known for f-body mods - he sells the brass replacement gears for Firebird headlight motors.
I have the sequential turn signals in my T/A and they are a real attention grabber. I almost consider them a safety item because people really notice when you use them. I even had a guy in a BMW follow me into a parking lot to ask where I got them.
Old Dec 14, 2007 | 08:50 AM
mermel's Avatar
Thanks, WhiteBird, but I have all the electrical know-how of a brick, so I think I'll get someone more experienced than I to install this kit.
Old Dec 14, 2007 | 08:57 AM
Actually, it's quite easy. If you can connect the wiring for a stereo then you can do this mod. It's just a case of adding a dual filament bulb socket for the outer segment to replace the factory single filament socket and then connecting the wires. If you don't want the sequencing to happen when the brakes are applied then you also need to run a pair of wires up to the steering column to connect there.
Then you might have to play around with different flashers until you get the timing right. I think it was the fourth flasher I tried that finally was slow enough.
Old Dec 14, 2007 | 11:48 AM
mermel's Avatar
I can hook up speakers to a stereo, but the instructions talk about cutting and tracing and shortening wires and all kinds of stuff that I know nothing about.
And I don't understand what you mean by "fourth flasher," but I DO want the sequence to happen when I brake.
To be honest, I'd rather set it up so that the lights alternate as opposed to sequentially light up. So instead of going "OFF-I-IM-IMO-OFF" (I - inside, M - middle, O - outside) it would go "OFF-I-M-O-M-I-M-O-etc." Any idea how to do that?
Old Dec 14, 2007 | 12:55 PM
No tracing is necessary - I can tell you where to find the necessary wires and what color they are.
I meant that I bought several different flashers in an effort to find one that would cycle slow enough that the light sequencing would have the desired effect. It was the fourth or fifth one I tried that finally ran slow enough.
I don't know of a way to do that other than creating your own electronic module and providing an alternate power source. You're not allowing for an off cycle in that pattern but the power coming from the turn signal switch is an on-off pattern. Not to mention that what you're suggesting would be confusing to people behind you. The sequential pattern moves from inside to outside making the direction of the signal obvious.
Old Dec 14, 2007 | 01:16 PM
mermel's Avatar
Ok, then from what you're telling me there's only one thing stopping me from doing this myself. I don't have or have access to (or even know what it is) a Dremel. It says I have to cut my taillight in the back in a way that would allow the outer light to illuminate during braking and turning.
I'm very scared when I do something to my car myself since I don't know what I'm doing. One thing done wrong and it won't work. Give me a computer, a screwdriver, and a RAM tester and I can troubleshoot anything computer-wise, but I know nothing when it comes to cars (don't even know how to change my own oil).
Old Dec 14, 2007 | 01:24 PM
A Dremel is the brand name of a rotary tool. It is somewhat similar to a drill but it's designed to use various cutting and grinding tips.
There is an existing bulb and socket in the outboard segment of the taillight but it's a single filament bulb that only works with the running lights. You need to install a dual filament bulb and socket there so that it will work with the brakes and turn signals as well as the running lights. Dual filament bulbs and sockets are larger than the single filament ones so you use the rotary tool to enlarge the existing hole to fit the new socket. You could do it with a sharp knife if you're patient but you can get a rotary tool from Harbor Freight for $20 (they even have a 12V model for $8).
Old Dec 14, 2007 | 01:51 PM
mermel's Avatar
Power tools and me don't mix either. I'll just get someone from my local FBody Association to do it. Still, many thanks for the link. Cheap for such a cool mod.
