Power Window Is Dead. Install help!!
Old Jun 27, 2003 | 07:15 AM
MYBLKSS's Avatar
Default Power Window Is Dead. Install help!!
I have the link for the install, but for some reason it is not working. Does anyone else have a write-up. Also is there any way to get around drilling threw the actual door to get to the rivets?
Here is the link I have http://home.swbell.net/shoebox/windowmotor.html
thanks
Old Jun 27, 2003 | 09:43 AM
TA TED's Avatar
STF Veteran
Default Re: Power Window Is Dead. Install help!!
No, you must drill out the existing pop rivets to use the nuts and bolts to attatch the new motor. It's pretty easy to do. You'll see that when you get in there. Just c-clamp the glass to keep it from falling, drill the rivets, line up the new motor and tighten the nuts. Plug in the connector and enjoy. Good luck.
Old Jun 27, 2003 | 11:12 AM
MYBLKSS's Avatar
What about the write-up is that the right link?
