Gauge wiring
Old Dec 23, 2007 | 01:20 PM
White 96LT1's Avatar
Question Gauge wiring
Ok i just got a Autometer electric oil pressure gauge along with a Autometer electric water temperature gauge and i know where to get my power and the ground but what wires do i tap into get my readings for the gauges signal?
Old Dec 23, 2007 | 01:45 PM
bryan04h's Avatar
are you asking where you need to put the sender and how to wire it back? or if you can wire into the instrument cluster?
Old Dec 23, 2007 | 02:04 PM
use existing sending units and splice into the wiring
Old Dec 23, 2007 | 02:12 PM
bryan04h's Avatar
you have to use the autometer sender and use a 16X1.5mm to 1/8 NPT adapter, as for the wiring, i think you can splice in the(checking sticky) ahh it is b14 tan wire on the pcm
Old Dec 23, 2007 | 02:17 PM
so b14 is for the oil pressure? Thanks
