Installed Pioneer DeH P5900IB and no fade control
HU works fine but no fade option is available in menu. Direction tell me to the multi control to witch rear output settings between "Rear SP:F.Range" to "Rear SP:S/W". Problem is I cannot find these speaker options when going through the menu.
Car is 02 Z06 with factory amp, just different HU.
Manual is wrong. I found a thread late last night. You have to go in through the install menu, same menu for setting clock. You cannot make the speaker change through the normal menu. At least that is how it is through the 5900.
Ungrounded Moderator
You're talking about ordinary fade and balance, right? Not some extra sub channel control or other unusual setting? The balance and fader control is a joystick-type operation on the main audio menu. You can't use many of those other controls when connected to the factory amp.
Manual makes you think thsi can be done while radio is operating.
