any problem with this?
Old Jan 24, 2008 | 03:44 PM
Wolfwoodx89's Avatar
Default any problem with this?
Im using an employee discount to get 4 kicker KS series speakers a 10" L7, and a 600 rms amp with 1200 peak i believe it was, all for 80% off.
Well I bought a walmart wiring kit. It claims its good for 1450 watts of peak power and 750 rms. Is there any problems foreseeable with using this wiring? I know its nothing high end of course, but if it works without putting me at risk of fire than Im fine with it.
Old Jan 24, 2008 | 11:18 PM
bmnicolosi's Avatar
i take it you work at circuit city? just a guess cause of the kicker deal--i work there too, but what amp is it you are getting?
Old Jan 25, 2008 | 12:23 AM
chromeplated500's Avatar
i was changin tires and doin an oil change on a monte carlo that had jumper cables ran to the battery to the amp. pretty classy. I've heard of people using the walmart ones, without a problem.
Old Jan 25, 2008 | 03:25 AM
KEE AUDIO's Avatar
It isn't so much the brand as it is what gauge the wires are. Some of the cheaper ones claim a certain gauge and then it really isn't. You need to be more concerned about the gauge of the wire...in this case no less than 4awg wire for power and ground with that much wattage should be fine.
Old Jan 25, 2008 | 11:02 PM
Chattanooga's Avatar
yea, brand doesnt matter at all
Its just dame wire... lol
But if you need 1500 watts, make sure its 4 gauge wire or a smaller number
I get my wire from a local hardware place for 10$
its decent size wire for the price, i think its 6 gauge
and it is great
Old Jan 28, 2008 | 06:48 PM
stewaj11's Avatar
Ya wire is wire, but with running that much power play it safe and run 4 gauge, i only do 8 for component amps. I always use off brand wire and havent had a problem with it.
Old Jan 28, 2008 | 06:59 PM
blackSSmoke01's Avatar
make sure the wiring you get is what you are actually wanting. alot of times the lower end brands claim to be 4 gauge but is really more like a 8 gauge wiring with a crap ton of plastic covering it.
Old Jan 28, 2008 | 08:34 PM
fredmr39's Avatar
Wire may be wire... but the nicer stuff still likely has it's benefits:
easier to work with (flexibility)
better looking
stronger insulation
greater Copper/Aluminum ratio
Old Jan 28, 2008 | 08:43 PM
pentavolvo's Avatar
that walmart is like 5 ga, no way its a real 4ga
Old Jan 28, 2008 | 09:49 PM
i ordered wiring off ebay that was supposed to be 8 gauge and was more like 16. I would just buy kicker wiring, it very flexible and a top notch product.
Old Jan 31, 2008 | 10:34 PM
Navy01Z's Avatar
Which brand from Walmart is it? I ask because I have seen at my local Walmart a couple different brands one of which being Scosche. Now I know it's not Scosche EFX but Scosche is a great brand of wiring. My shop has always used the EFX or Stinger and it's great stuff. Go 4ga for sure and you shouldn't have any problems.
