Beeping 12 Disc Changer...?
Old Feb 5, 2008 | 04:57 PM
SPECIALIZED STAINLESS's Avatar
Question Beeping 12 Disc Changer...?
My Monsoon 12 disk CD changer constantly beeps while playing a CD. It's the stock system in my 2001 SS. What could be causing this? I know I'm not the only one w/ this problem because I found this unanswered post: https://ls1tech.com/forums/showthrea...eeping+changer
Help
Old Feb 6, 2008 | 12:05 PM
Anyone??
Old Feb 7, 2008 | 07:29 PM
bump...
Old Mar 22, 2009 | 10:18 PM
hammertime's Avatar
Bump...I'm having the exact same issue...only hear a quiet pulse (approx 1 per second) though the factory CD Changer. No noise from the in-dash CD or the radio.
Any info - updates appreciated!
Old Mar 22, 2009 | 10:44 PM
hammertime's Avatar
Specialized,
I kept searching after I found your post and found this unanswered post, in addition to the one you posted above. I finally stumbled upon a possible fix here:
It's the connection going into the cd changer. Check that. I would have the same problem. Half of the speakers would go muted and you would hear beeping sounds coming from the remainder of the speakers. I had my changer in the back seat, behind the driver, and I would disconnect the changer and replug it back in and it would go away.
I went out to the garage and tried to test for this before removing and reconnecting the cable, but I couldn't make it beep with the key in accessory or in run position. I did not want to start the car since my wife is already sleeping, but it was beeping when we went to dinner earlier today.
I did remove and reseat the connector as described above, and I'll report my results tomorrow after I get a chance to drive it.
