Fuse: Door locks and Map/Dome lights
Took the SS for a spin today after setting in storage for awhile. The battery was pretty low but it was able to start then I kept hearing a click sound over by the pass side glove compartment it sounded like. I guess it was probably a relay clicking. Then I notice none of the interior dome/map lights work and also the door locks were not working. I looked for a fuse for a few seconds but could not find one. Could this be a bad relay or maybe the battery was just too low? Last time I got it out I forgot the wrench so I just put the battery cables on as tight as I could by hand and that was the first time I had it out in a long time and the first time I noticed the clicking but I think the locks and lights worked then. What you guys think the issue is?? Im going to take the battery out tomorrow and charge it, then ill prob buy a trickle charger for it.
