Can my amp sufficiently power my setup?
OK.
Right now I have the following things,
JL Audio VR650-CSi front components
# Sensitivity: 89.5 dB
# RMS Power Range : 60 Watts
Infinity Reference 7541a 4 channel amplifier
# 4-Channel car amplifier
# CEA-2006 compliant
# RMS Power @ 4 ohms: 111 watts x 4
# RMS Power @ 2 ohms: 139 watts x 4
# RMS Power @ 4 ohms bridged: 278 watts x 2
Now, I want to buy a 10 inch subwoofer with the t-top enclosure, could my amplifer power everything fine? Or would I need a separate amp for the subwoofer?
Also, I wanted to buy some speakers for the rear. Either for the sail panels, or to replace the speakers I have in the hatch. Maybe I would run these speakers off the head unit if possible. Any recommendations?
Any help is appreciated, thanks.
In my truck I'm using that same amp to do that. I have a set of MB Quart speakers up front running at 139 watts and the rear two bridged powering a kicker shallow mount sub. The speakers sound great, the sub is lacking a bit. Could be the combination of it being a shallow mount, shoved behind the seat, and only 278 watts...
