Adding amp question
Old Feb 14, 2008 | 02:59 PM
Art Vandelay's Avatar
Default Adding amp question
I'm adding an amp to the monsoon system for a stealthbox and using line-level converters. A number of people have recommended getting the signal before the amp. I've already disconnected the rear hatch speakers, but if I use the rear speaker wires for my rca's, will I still be able to use the rear subs? I'm assuming since there are only one set of wires going to the amp for the rear speakers, if I disconnect the wires before the amp, the amp will not power the rear hatch or subwoofers? Any ideas?
Old Feb 14, 2008 | 06:26 PM
WhiteBird00's Avatar
Ungrounded Moderator
Don't disconnect the wires before the amp - just tap into them there. It's really the only way to get speaker-level (unboosted), full range signal. If you have a Camaro, you can also get full-range signal at the hatch speakers but a Firebird has filtered signal there.
