DEI 508T install
Old Feb 19, 2008 | 05:55 PM
copekyle's Avatar
Default DEI 508T install
I found a guide about two months ago to install this DEI 508 proximity sensor into the center console. THe wires are apparently running under the center console. Does anyone know where this guide can be found? THanks in advance!!
Old Feb 19, 2008 | 06:04 PM
swandogg25's Avatar
Do a search in this section for proximity sensor and you will find what you need.
Old Feb 19, 2008 | 08:51 PM
WhiteBird00's Avatar
Ungrounded Moderator
If you're talking about adding it to the stock alarm system, the wires aren't in the console. You want to tap into the same wires as the shock sensor except that the green and blue wires have to be reversed (blue is warn away on the shock sensor but full alarm on the perimiter sensor and vice versa for the green). You can get to the wires in the large blue connector on the BCM.
