No sound from speakers
To make sure you radio is ok, get the speaker wires from the car radio and get extra wire and connect them to a speaker you should get sound and then you'll know your radio is ok and you may have used the wrong wire. Also check your fuses. Also check the setting on the car radio it may be set to the rear only.
