Kinda a noob here.
Old Feb 27, 2008 | 09:17 PM
NBM-LS1's Avatar
Default Kinda a noob here.
Im trying to get this straight.
2ohm, dual voice coil speaker wired in series = 4ohm load?
or
2ohm, dual voice coil speaker wired in parallel = 1ohm load?
Sorry if your irritated and answer these questions all the time.
Im cheap and going with a Cerwin Vega V MAX 10.2 10 Inch 1200 Watt Subwoofer
and a Soundstorm 1500 watt class D mono amp.
The sub description says it can be wired as 1ohm and the amp could handle 1ohm load. So will these work together?
Thanks, Matt-
Old Feb 27, 2008 | 09:46 PM
Gordon0652's Avatar
What does the amp put out at a 1 and a 2 ohm load. If that amp can even handle a 1 phm load.
Old Feb 27, 2008 | 09:50 PM
NBM-LS1's Avatar
It says it can handle it.
1500watt monoblock class D amp
1500W x 1 max power at 1ohm
1200W x 1 max power at 2ohm
1000W x 1 RMS at 2ohm
900W x1 Max power at 4ohm
540 x1 RMS power at 4ohm
Old Feb 27, 2008 | 09:56 PM
Gordon0652's Avatar
How many subs? Then i can help you.
NBM-LS1's Avatar
Just one.
Old Feb 27, 2008 | 09:58 PM
Gordon0652's Avatar
[/SIZE][/FONT]
Thats because your Sub RMS is 600 watts, and i wouldnt push that sub.
Also there is better subs for the same price.
Old Feb 28, 2008 | 08:16 AM
KEE AUDIO's Avatar
Your not exactly cheaping out on the sub. That sub runs about $120.00. For about $30.00 more your in RE Audio land which is a great sub. I have a brand new NIB MA Audio MA1000XL I bought for someone and they changed there mind and went with the CDT. If you want it it's yours for $80.00 shipped. This is a beefy sub.
Old Feb 28, 2008 | 01:27 PM
NBM-LS1's Avatar
That doesnt look like it would fit in a stealth driver side box.
Old Feb 28, 2008 | 03:25 PM
KEE AUDIO's Avatar
That's what it was going to go in. One of my stealth enclosures.
Old Feb 28, 2008 | 07:21 PM
cws T/A's Avatar
http://www.the12volt.com/caraudio/wo...igurations.asp
Old Feb 28, 2008 | 08:45 PM
NBM-LS1's Avatar
So my current setup is an 8" JL 8W1v2-8. Optimum rms is 125w. This is also an 8ohm speaker. My amp is an Eclipse EA2000. It says the max output is 175x1 at 4ohm. Since my speaker is an 8ohm amp does that mean I am only getting half of the power the amp is producing?
Old Feb 29, 2008 | 10:06 AM
KEE AUDIO's Avatar
Yes. You are currently getting about 87.5 watts to your 8W1v2. If your sub has dual voice coils you could drop the impedance down. Or if you were running more than one speaker.
8ohm speakers are generally for home theater applications. 4ohm or less is generally for car audio.
Old Mar 1, 2008 | 11:36 PM
I-10 b4c runner's Avatar
either buy 2 4 ohm woofs and wire them to a 2ohm load
or
4 ohm Dual voice coil if you are going with a single sub of which you also wire to a 2 ohm load
Old Mar 2, 2008 | 02:25 PM
WhiteBird00's Avatar
Ungrounded Moderator
or
No, the EA2000 is not 2-ohm stable. He needs 4-ohms for that amp.
Old Mar 2, 2008 | 09:05 PM
NBM-LS1's Avatar
Yep. I am just going to keep my setup the way it is. Its got a bit of a kick and does well. Thanks for all of the help.
