2 ohm amp with 4 ohm speakers?
Is this a good idea?
I just bought a 2 ohm amp and im thinking i can still use to run 4 ohm speakers?
Or, can i run a 4 ohm 12inch subwoofer?
Its 280 brigded.
Its 280 brigded.
The reverse is not true - you can't run lower impedance than what the amp is rated stable for (i.e. don't run a 1-ohm load on a 2-ohm stable amp). Lower impedance increases current flow causing more heat and damaging the amp (except for the protection circuit built-in to many amps).
