BCM Bypass and wire clean-up
I assumed I could bypass the BCM entirely at this point but when I disconnect the BMC it will not crank. What wires are a must???
Thanks!
You will have to provide an independent ground for the starter relay since the BCM would normally do that after it was satisfied that the correct key was in the ignition. This is a simple matter of grounding the yellow with black wire.
Thanks for your response WB, just to clarify...prior to BCM. Splice (both?) black wires and the one yellow wire, twist together, ground to chassis?
Thanks!
