window motor
Old Feb 27, 2008 | 02:26 PM
Gregorya24's Avatar
Default window motor
my drivers side window will roll up about 3/4th's and stop, i have to wait about 30 secs till whenever it decides to go up. Is the motor going bad or what else could it be?
Old Feb 27, 2008 | 02:28 PM
Player87's Avatar
yeah sounds like the motor is going bad.
thats normal. i had this also with my car.
but you need about 30 to 60 minutes to repair this.
Old Feb 27, 2008 | 02:39 PM
turbozcamaro's Avatar
it is a bad motor, mine did the same thing
Old Feb 27, 2008 | 02:48 PM
Gregorya24's Avatar
how much does a new motor run ya?
Old Feb 27, 2008 | 03:09 PM
presto_z's Avatar
the search is your friend
its a bad motor. changing the window motor is not bad at all if you
follow this write up
http://shbox.com/page/windowmotor.html
i found an easier way to support the window then in that right up.. here is a pic i took
you can get motors at discount auto for 50 bucks with a lifetime warranty..
the first one may take you awhile, but they are a breeze after that.. ive done 5 or so, my two and a few for other people.. i actually have a Tupperware container with everything i need in it lol
hope this helps
Old Feb 28, 2008 | 05:17 PM
NINO_SS's Avatar
I have a question what does it mean is the window motor just goes down and keeps running also when you press it to go up it stops but when you let go its running?
Old Mar 1, 2008 | 12:40 PM
RedZ99's Avatar
ah ha! Thank you Mr. Presto! I've done the driver's side motor, and was paranoid the whole time that the hose method of supporting the glass was going to crap out on me. Now the pass side is starting to go; the 2x4 trick is gonna be much better.
Nino, i think the down, at least, is on a timer circuit. Don't know about the up. I wouldn't worry about it unless the motor runs beyond several seconds.
Old Mar 3, 2008 | 07:30 PM
ShowstoppaTransAm's Avatar
mine was doing the same thing. you can get a motor off ebay for about 20 bucks shipped with a lifetime warranty or about 60 from autozone with taxes. the cheapest price i got for labor was about 150. if you do it yourself don't do it alone. you'll have to drill out the 4 rivits on the regulator then once you get the regulator and motor off the car you'll drill another 4 bolts that hold the motor to the regulator. USE CAUTION the motor is spring loaded to the regulator. you can also get a new motor and regulator already attached together from autozone for 125 , but they have to order it.
Old Mar 3, 2008 | 07:40 PM
pentavolvo's Avatar
actually if u read the writeup u can do it urself and no need at all to remove the regulator
after doing my drivers side i did passenger side in 45 min with door panel removal
Old Mar 9, 2008 | 09:33 PM
Default window motor instal
there is no way to do change the motor with out removeing the regulator. the motor is rivited to the regulator and under pressure from the coil spring.
Old Mar 9, 2008 | 09:52 PM
presto_z's Avatar
READ THE WRITE UP THAT I POSTED!!!!! ive changed many of these.. you are making this harder then it ever should be (twss)
EDIT: THERE IS NO NEED TO REMOVE THE REGULTOR!!!!
Old Mar 10, 2008 | 02:12 PM
VIP1's Avatar
Copy & Paste Moderator
Correct!
