How to disable Security Light...Cluster is already out!
I took out the cluster, looked for a place to unplug the light, but i see none on the back. I thought there'd be cables running to each light but that isn't the case. I'm just wondering, since i already have the cluster out, how do i disable the security light from coming on? Any help would be appreciated.
good luck
So do you think I'm just running into the same problem everyone else is? Most people seem to have trouble starting their cars when the light is on. I do not have a remote start option and I also haven't had a single issue starting it.
It sounds like the second situation happened in your case. The problem is that once the BCM is reset (e.g. by disconnecting the battery for service) the second situation can become the first - the car won't start. I would suggest trying the usual fixes for VATS problems and then maybe bypass the VATS system if you still can't get the light to go off.
I know you think #2 happened, but the very first time i EVER saw the security light was while starting the car yesterday. I would think that if it was #2, the light would've came on while i was driving. Since it came on before i started it, i would've thought if the VATS was going bad, it already would have since the light was on. I'm still confused.
In addition to keeping bad people out, the door locks are a key safety feature. In a bad crash, they help to keep the door from opening and thus help keep occupants from being ejected. (This is why many late model cars now have automatic door locks.)
Granted, although I'm sure I would open the door if a carjacker is standing there with a gun pointed at me. I lock only those doors next to empty seats to prevent somebody from just jumping in uninvited.
Sorry, no. A door that is unlocked will not be any less secure than a locked one. The latch strength is the same in either case. Locking the door merely disconnects the handles from the opening the latch - the latch is mechanically holding the door closed in exactly the same way regardless of whether locked or unlocked.
That's what seat belts are for! Anyone who is concerned enough about crash safety to worry about whether a locked door would better keep them from being ejected wouldn't be foolish enough to drive without seat belts.
The primary disadvantage of locked doors...if you are incapacitated because of an accident (or heart attack, etc.) then any rescuer has to break into the car to get you out. People who are paid for that (police, fire department, etc.) will normally have the tools to do it but your average good samaritan doesn't. It's even worse with recent model cars. Older cars used to disengage only the outside handle when the door was locked - you could still open the door from inside by just pulling the handle. Recent models disengage the inside handles as well, so the occupant can't get out without first unlocking the door before pulling the door handle. This may not seem like much but in a panic situation it could be a life or death issue.
Ture - there are two sides to the debate. In most engineering circles, arguments for keeping doors unlocked are concidered to be urban myth because we all have a greater chance of being ejected in a crash than coming across a situation where a locked door would be bad. (This would probably be a good one for the Mythbusters! OK - I'm a fan.) The statistics/equation also changes depending on the car, year, door, etc.
There are defiintely cons to having your doors locked. From the outside, EMS technicians can easliy get in to a locked car. From the inside, I carry one of these in all my vehicles: http://www.redboxtools.com/detail.cfm?productID=1482 Press it against any window and it will shatter if you are trapped in the car. (Also handy if one finds themself in a good samaritin situation.)
Normal seatbelts won't keep a passenger in the car by themselves. If the car spins or flips, one can still be ejected. (Only a 5+ point harness can protect against this alone.) The door and seatbelt together keep people in. That being said, the door latch is the primary protection to keep the door from opening. The flaw in our doors is the linkage in the door that connect the handles together. If these rods get bent in a crash, they can cause create an action similar to pulling up on the door handle, which will disengage the latch. The door lock protects against that scenario from happening. Newer cars are starting to be made with cable releases instead of the mechanical linkages to help solve this complication.
BTW - Here's one that will bring tears to our eyes: http://www.car-accidents.com/pages/a...ry/5-5-01.html (I don't think locking the door would have had any impact on this outcome! - Our roof hatches are probably a greater hazzard to us?)
I suppose you could disable the light by disconnecting or cutting the ground control wire at the BCM but it is probably better to determine why it's staying on rather than risk being stranded some day.
