Daytime Running Lights
Old Apr 28, 2008 | 12:38 PM
slaptastic's Avatar
Default Daytime Running Lights
I'm putting the 10k resistor in place of the sensor and I was looking at resistors and there are a bunch of different watts. How many watts should I get in the resistor?
Old Apr 28, 2008 | 01:17 PM
WhiteBird00's Avatar
Ungrounded Moderator
No resistor is necessary (or even desireable). Just connect the two sensor wires together... zero resistance = bright daylight = no automatic headlights. A really easy way to do that is to crimp a scotchlock connector over the two wires.
BTW, we're talking about automatic headlights...DRLs are the amber lights in front and it takes a different mod to disable them.
Old Apr 28, 2008 | 01:46 PM
Hatchetman337's Avatar
Why would you want to disable the yellow lights, though? They look cool coming down the road at you.
Old Apr 28, 2008 | 02:24 PM
I agree. I just wanted to make sure we were talking about the same lights to disable.
Old May 1, 2008 | 11:23 AM
slaptastic's Avatar
Thanks!
Old May 1, 2008 | 05:29 PM
cookba's Avatar
you have to lift up the dash to do the scotch lok trick dont you? how did everyone do it? im afraid of cracking the dash in half
Old May 2, 2008 | 09:29 PM
jsteele90's Avatar
i think you can remove the headunit and reach behind there to do it
Old May 3, 2008 | 12:29 AM
The Guz's Avatar
http://www.xse.com/leres/ss/drl.html
