Wiring harness problem
Old Aug 10, 2003 | 10:24 PM
Mint98's Avatar
Default Wiring harness problem
Can anyone tell me how to get the wiring harness disconnected by the power brake booster? I am trying to paint under hood area. Any input would be great.
Thanks
Mike
Old Aug 13, 2003 | 06:18 AM
TA TED's Avatar
STF Veteran
Default Re: Wiring harness problem
If you are referring to the main wire bundle that runs thru the firewall thru a black connector looking piece, then you are probably out of luck. That isn't a connector but a plastic enclosed feedthru point. You may be able to disconnect it from under the dash and pull it thru the engine bay, but it's not an actual connector.
