Couple Audio Questions
Lastly, the previous owner installed an aftermarket HU and I want a stock unit instead. My question is, what is the difference in the stock Monsoon and a Bose unit; are they a direct plug-in of each other?
Thanks
The Monsoon system uses a completely ordinary head unit. The only way to tell a Monsoon head unit from a base Delco unit is by the Monsoon logo - and many Monsoon systems didn't even have that. The "system" in a Monsoon is all in the external amp and matched speakers.
It sounds like the previous owner modified the system in a way that's fairly common for those who know how the Monsoon is set up. He probably replaced the sail panel subs with coaxial (full range) speakers. Since the factory signal to the sail panels is bass only, pulling the hatch speaker wires forward to the sail panels is a good way to get full range signal there.
Since I want to install a factory head unit does it matter if it's a Monsoon or 'regular' head unit? Like I mentioned, there is an amp in the passenger quarter so this would leave me to believe that my car originally came with a Monsoon?
If you want to confirm that the car originally had a Monsoon, look for option code UZ7 on the door sticker (assuming it's the Camaro in your signature...W54 or W55 for a FireBird).
