Steering wheel control question
Old Jun 15, 2008 | 11:19 AM
Ironxcross's Avatar
Default Steering wheel control question
I recently bought and installed a pioneer headunit. I noticed the second plug from the gm unit had no spots on the new headunit, so I left it off. After getting the radio dialed in, I noticed that my steering wheel controls were not active anymore. I'm guessing that was the plug that I didn't plug in. Is there a way to convert that over to the radio so I can have steering wheel controls with the new radio?
Old Jun 15, 2008 | 11:39 AM
cookba's Avatar
yes there is an adapter you can buy most likely. well atleast there was for my Alpine unit i bought.
Old Jun 15, 2008 | 12:02 PM
Ironxcross's Avatar
well i went to best buy and they tried to sell me some $100 unit that needed to be wired up. I'm wondering if theres a cheaper way to do this.
Old Jun 15, 2008 | 12:24 PM
cookba's Avatar
weird, i bought mine from crutchfield and that piece was only like $30. check there site and see what they have. best buy never impressed me with their car audio "guru's".
Old Jun 15, 2008 | 01:25 PM
Ironxcross's Avatar
Yeah. The other part they didn't tell me is that the one antenna plug needs a converter for the larger port on the pioneer unit, so I went to best buy and that was another $13.
Old Jun 15, 2008 | 01:32 PM
Ironxcross's Avatar
well I went to that site, which is very cool btw. All I found was this:"
http://www.crutchfield.com/App/Produ...7SWIPS&tp=3405
the same thing the best buy guy offered me. Is there anything else out there? I don't want to pay $70.
Old Jun 15, 2008 | 02:01 PM
vjo90rs8's Avatar
That is the only way to make them work. I picked up a Alpine head unit and just bought the SWI-JACK from ebay for $45 shipped. Just search SWI-PS and I'm sure you will find a good deal.
BTW, there are too many different types of cars out there and its almost impossible to make the aftermarket head units work will all these steering wheel controls. The PAC unit takes the steering wheel control output and converts it to something that the head unit can understand.
Old Jun 15, 2008 | 02:17 PM
95TAJade's Avatar
that there is an awesome part! I've got it hooked up with my Pioneer H/U and it works great! that and all the wires (4 if i remember right) are all right there in the radio harness!
Ironxcross's Avatar
I see. So there is no cheap alternative. Thats a shame.
Old Jun 15, 2008 | 03:27 PM
vjo90rs8's Avatar
I was debating back and forth whether or not I should do it with my car. I figured, add $45 and do it right the first time. I know I would regret it later.
Old Jun 15, 2008 | 04:05 PM
jsteele90's Avatar
dont you have to solder in some resistors and what not with that swi-jack kit?
Old Jun 15, 2008 | 04:34 PM
vjo90rs8's Avatar
according to the installation instructions you only have to use resistors if the steering wheel controls have a wire for each button, would not be used with our cars.
Old Jun 15, 2008 | 05:22 PM
WhiteBird00's Avatar
Ungrounded Moderator
To install the SWI-PS in an f-body, red goes to switched power, black goes to ground, green goes to the dark blue wire in the factory harness (there is no corresponding wire in the harness adapter), and the 1/8" plug goes to the wired remote jack on the back of the head unit.
BTW, that extra harness you didn't use is for the factory CD changer. The harness is installed even if you didn't get a factory changer.
Old Jun 15, 2008 | 06:10 PM
jsteele90's Avatar
awesome now all i need to do is find someone selling one. cause im not buying a new one those things are way to expensive to buy new. i can just use the head unit until then.
