Electrical trouble
Old Jun 16, 2008 | 01:17 AM
Teakwo23's Avatar
Default Electrical trouble
Hey guys, my dome light will not come on when I open the drivers side door. Works fine on passenger side. Also the radio will not go off when I open the door. Works fine on passenger side. Any idea whats up?
Old Jun 16, 2008 | 12:01 PM
VIP1's Avatar
Copy & Paste Moderator
The switch in the driver's side door latch is not operating properly. It either needs to be cleaned, adjusted or replaced.
Old Jun 16, 2008 | 11:48 PM
Teakwo23's Avatar
Is there anyway I can adjust it?
Old Jun 17, 2008 | 08:57 AM
VIP1's Avatar
WhiteBird00 knows more about it. Maybe he'll chime in here, or you can PM him. I haven't had to work on mine yet.
Old Jun 17, 2008 | 09:37 AM
WhiteBird00's Avatar
Ungrounded Moderator
The door switch is mounted to the door latch mechanism (unlike older models that had pin switches in the door jamb). There is a small amount of adjustment with the mounting screws but that usually isn't the problem. More often the problem is that the switch is gummed up with road grime. A good shot of spray contact cleaner from Radio Shack (TV tuner cleaner will work as well) will usually take care of it.
Old Jun 17, 2008 | 11:29 PM
VIP1's Avatar
That part I knew (from a previous post of yours). What I'm unsure on is how/where? Is it obvious where the switch is in the latch (I know where the latch is)? Is there a diagram somewhere?
Old Jun 18, 2008 | 01:19 AM
Teakwo23's Avatar
Im not sure. I'll take a look at it more and try to clean it out. Thank you.
