lost power windows and radio
Old Jun 19, 2008 | 03:06 PM
1lt1wiz's Avatar
Exclamation lost power windows and radio
i lost power windows and radio the fuse is not blown any help
Old Jun 19, 2008 | 04:37 PM
phantomzer0's Avatar
It's the BCM. If you search the forum, I know you can find an answer. Search BCM.
Old Jun 20, 2008 | 07:13 AM
WhiteBird00's Avatar
Ungrounded Moderator
But double check the fuses first. Never trust a visual inspection - a fuse can look fine but still be blown. Get a fuse tester, a multimeter, or replace with a known good fuse to be sure. In particular, check the COURTESY fuse. Although it doesn't directly power the radio or windows, it does power the BCM which controls the retained accessory power circuit.
Old Jun 20, 2008 | 04:25 PM
1lt1wiz's Avatar
Exclamation i
i checked thoes fusses and they all tested okay
Old Jun 20, 2008 | 04:30 PM
Richiec77's Avatar
Then the next component in line is the BCM.
