optima yellow top and alternator
For alts. I got mine at jegs, I 'm really happy with it . It was a real pain-in-the-a$$ to install, until I dropped the swaybar down and before I finally realized I had to clock the the back of the alternator ,after that It was easy!
Make sure you do the "Big 3" when you up-grade your alternator.
Otherwise that new high-output will not be very effective!
Also check out excessiveamperage.com and Iraggi-Alternator on ebay .
Here's the chart direct from Optima:
http://www.optimabatteries.com/optim...ical_specs.php
with no problem! and on top of that a slp underdrive crank pulley. I did bump up my idle to 850rpm though.
IMO run the 1/0 guage wire for the "Big 3."
You'll need about 5-6 ' from alt to batt.+ , around 1.5' from eng./alt.body to chassis ground on drivers side, and 1" from - batt to chassis ground on passenger side.
For the "Big 3" I did it all myself.
But,You can always buy the cable and 6 crimp on terminals cheaper online ,then take them to a audio shop and for a small fee have them cut to length and the terminals crimped on. And for added cable protection 3/4" flex loom to put over the 1/0 cable.
I would install the wire into the terminal, Divit the middle of the crimp area, and then basically fold the terminal in on it'self by means of using a bolt cutter. A vice works damn nice. Crimpers for large sized terminals basically do the same thing in 1 action verses 2-3 or so.
http://www.delcity.net/delcity/servl...d=10383&page=1
IMO, The best choice is going to be "Your Choice" by taking the next step yourself and doing some of the leg-work so you can make a informed decision that best Suits YOUR needs.
Alterstart
Excessiveamperage.com
Powermaster
pt # 58203, You will have to clock the case per powermaster directions, and youll probably have to slightly bend / move some of the hard lines coming off the steering rack for clearance, and drop the swaybar which will make the removal / install a lot easier!
