Bizzare window switch
Old Jul 2, 2008 | 09:42 PM
SantaCruz163's Avatar
Default Bizzare window switch
My driver's window works fine but the passenger side is giving me some issues.
1. I can only roll the window down with the driver's control
2. I can only roll the window up with the passenger's control
Has anyone experienced this sort of thing?
Old Jul 3, 2008 | 02:42 PM
wssix99's Avatar
Save the manuals!
Yea - This guy has the same issue. https://ls1tech.com/forums/wiring-stereo-electronics/940214-window-motor-issue-help.html
The passenger side switch is wired through the driver's side switch. A bad contact in the driver's side switch module is one scenario that could cause this behavior. You'd need a schematic and a continuity tester to confirm if the switch is bad.
