Monsoon new head unit
Old Jun 30, 2008 | 06:53 PM
Ryan1998TA's Avatar
Default Monsoon new head unit
i wanted to get a new head unit but every shop i take it to says you don't wanna replace that head unit because then everything will sound bad but i really wanna hook my i-pod in and have sat radio but mostly i-pod will this radio be a good choice Kenwood Excelon KDC-X592 or must i replace the whole system?
if i can use an aftermarket what should i look for ?
98 t/a monsoon c/d
Old Jun 30, 2008 | 07:19 PM
tasilver's Avatar
Dont listen to them. I put off buying a new HU for a year because of the BS untill found this sight. I hate to think where car would be If this sight did not exist.
Just use the regular gm harness adaptor and a head unit that fits. I use a alpine CDA-9855 it is 18 watts rms x 4. It sounds much better than stock. You just do not want to buy a very powerful deck, The reason is you only be able to turn it to level 6 as apossed to level 20 (less range of sound because of the stock amp). As long as you put in low power level deck it will sound great.
I now have elimental subs in sail pannels and a stealth box in the rear (self powered). The car sounds great.
oh yeah before any one else says it, Search is your friend (when it works).
Old Jun 30, 2008 | 10:56 PM
VIP1's Avatar
Copy & Paste Moderator
All you need to replace the stock Monsoon headunit:
* New headunit
* Mounting Kit
* Wiring Harness
* Antenna Adapter
* Steering Wheel Control adapter
To clarify the steering wheel control adapter, the PAC SWI-X is the universal IR one. PAC also makes brand specific wired units as well (ex: SWI-PS is for Pioneer headunits with the remote port on the back).
The aftermarket headunit will sound much better (clearer overall with better bass) than the stock Monsoon headunit.
Check out the Monsoon FAQ sticky:
https://ls1tech.com/forums/wiring-stereo-electronics/612644-monsoon-faq.html
... and the general FAQ sticky:
https://ls1tech.com/forums/wiring-stereo-electronics/303776-frequently-asked-questions.html
A search would help too.
Old Jun 30, 2008 | 11:10 PM
Ryan1998TA's Avatar
do i have to get one with 6 Preamp Outputs or can i use any?
Old Jun 30, 2008 | 11:15 PM
ws6spd's Avatar
I just did this a couple weeks ago, see my thread here in Stereo Electronics about replacing the monsoon.
https://ls1tech.com/forums/wiring-stereo-electronics/942985-finally-replaced-monsoon-ta.html
I really recommend an HU that has an USB input which can be used for an IPOD or just a plain old USB memory stick.
The Pioneer 5000 I got has it and I have an 8GB stick in it and its awesome.
Don't hold back, the install is very easy if you want to do it your self or some stores install for free with HU's over 150 bucks depending where you live.
I was/am blown away by how awesome the factory speakers sound with just the HU upgrade.
I was thinking of an amp and a stealth box before I installed but now I'm not sure cause the bass from the fact stealth speakers is good enough if you listen to music at the safe hearing level
Old Jul 1, 2008 | 12:13 AM
VIP1's Avatar
No. Almost any headunit with a built-in amp will work (most headunits). In the stock setup, the Monsoon headunit provides the standard 4 speaker-level outputs to the amp which in-turn amplifies that signal and splits it to the speakers (there are some differences between years and between the Firebird and Camaro, but that is the general of it.) Check out the FAQs/Stickies for more info.
Old Jul 1, 2008 | 07:50 AM
bobbyd's Avatar
https://ls1tech.com/forums/showthread.php?t=942985
yea I saw your thread and I got the same unit myself should be here on thursday.
where exactly is the usb port at? do you have a picture of yours on your car?
Old Jul 2, 2008 | 02:06 PM
slt200mph's Avatar
If the stock speakers blew you away you will not beleive how much better some quality aftermarket speakers will sound...monsoon head unit .. = .. .. and the same with the monsoon speakers = ..
Old Jul 2, 2008 | 07:16 PM
ws6spd's Avatar
I don't doubt it, but I'm fine with the stock speakers this year or until they blow...
Old Jul 2, 2008 | 07:21 PM
ws6spd's Avatar
You can run the USB any where you want. THey come with 3 - 4 ft of USB cable attached to the back of the HU.
I haven't decided on an permanent place yet, so I've just got it coming out between the HVAC section and the Shifter/console. I'm condering running it into the arm rest and securing it to one of the sides.
Old Jul 3, 2008 | 07:30 PM
ManicMechanik's Avatar
Dunno about it bein dog squeeze. I like it much better than the Bose, and the EQ is great. It rocks fer stock.
