upgrade alternator
Old Jul 16, 2008 | 05:30 AM
GTP PWR's Avatar
Default upgrade alternator
what aftermarket alternators are out there? I have gone through Advance Auto parts, O'Reilly auto, and Autozone's website...so far have found a 145amp from a silverado......
I see the 160amp alternators on ebay all the time...has anyone used these?
looking for the biggest alternator I can find that will bolt up to an LS1....
Old Jul 16, 2008 | 06:51 AM
MeentSS02's Avatar
Kleeborp the Moderator™
I went with an Alterstart 200 amp...it uses a different case, but still bolts right up. So far, it has been great, but I don't daily drive my car anymore like I used to. I certainly don't have any voltage drop with it, and I drive a small stereo system with it. I mainly wanted it to help offset the electrical draw of my electric water pump and my soon to be upgraded fuel pump(s).
Previous to that, I had a 160 amp alternator from Afterthoughts Auto (they contracted it out to someone else), but it died on me, and I never did get it fixed.
Old Jul 16, 2008 | 07:37 AM
WhiteBird00's Avatar
Ungrounded Moderator
It depends on what you're looking for. There are 200A and 235A alternators that fit LS1s. If you're looking for power at idle, the 200A actually puts out more amperage at idle than the 235A. The 235A has more output at higher engine speeds.
I went with the 200A because I was looking for something that could handle air conditioning, wipers, lights, etc. while sitting in traffic (a common situation in Florida).
Old Jul 16, 2008 | 05:47 PM
99Bluz28's Avatar
Cool
Come on! At least attempt a search.
https://ls1tech.com/forums/wiring-stereo-electronics/947480-help-installed-ho-alternator-02-camaro.html
Old Jul 18, 2008 | 04:32 AM
GTP PWR's Avatar
powermaster huh......
and I did search.... I went through the sticky at the top that labels...most common topics. the alternator was not in there...so I made a post.
where did you guys order your alternators? I normally use Advance..as they kick butt here in town for having upgrades, but this time they only had the stock 105amp. the autozone(which I hate) here in town has a 130-145amp.....I will check out the mounting with my old one. 200some for a stock alternator..I would rather spend twice that and get near double. best to have over kill than to be stuck needing to upgrade later....
Old Jul 18, 2008 | 06:56 AM
MeentSS02's Avatar
Got mine from Ebay.
Old Jul 18, 2008 | 04:03 PM
99Bluz28's Avatar
Wink
I got my powermaster(part# 58203) from Jegs.
Here's a few more.
http://www.nationsautoelectric.com/h...FScuagodAl5KuA
http://www.4alterstart.com/highoutputalternators/
http://www.ohiogen.com/html/about_us.html
http://www.highoutputalternator.com/online-catalog.aspx
http://www.excessiveamperage.com/ *see Dal1as comment below*
http://stores.ebay.com/Iraggi-Altern...ors_W0QQfsubZ3
http://www.mechman.com/home.html
Hope this is enough for you.
Old Jul 18, 2008 | 04:44 PM
KEE AUDIO's Avatar
I also purchased mine from ebay a long while ago and it has worked flawlessly (160amp). I did do the big three upgrade when I swapped out the alternator as well to try and help my new one last a little longer and make it more efficient.
Old Jul 21, 2008 | 12:49 PM
Dal1as's Avatar
Do not use excessive amperage. Alternators are junk and the guy ripped me off.
Old Jul 21, 2008 | 02:20 PM
waltonscott's Avatar
purchased a 160A from ebay, works good. Although they are rated at a higher RPM than idle.
Old Jul 23, 2008 | 04:24 AM
GTP PWR's Avatar
Thanks for all the info!!!! I had bought a 130amp for a 2500 silverado to hold me by until I had found the right one for my truck. right now with all my stuff turned on, with the lights...I am slightly over 12V on the gauge.....
