How to run a pillar gauges
Old Jul 16, 2008 | 01:08 PM
00cls1camaross's Avatar
Default How to run a pillar gauges
i saw a write up on here, tried searching for a while. Can anyone help me out?
Old Jul 17, 2008 | 01:13 PM
Tttttttttt
Old Jul 17, 2008 | 01:51 PM
Mean Green z28's Avatar
Pull your driver side vent out and pop the light switch out, there's a bunch of room in there to play around.
Crimp/Solder the common wires together from the gauges and the lights and make the supply wires; you should have three supply wires (ground, power and lights), and the signal wires when you've got the pillars mounted and connected together.
Mount the pillar pod on the a-pillar trim and run the wires behind and into the trim by drilling a hole in the trim.
Run the wires behind the trim and into the dash. You can get power from the fuse box for the gauges, there's an acc. terminal (use an inline fuse between that and your gauges). Ground can be run to the the steering column (it's a 10mm nut that holds the V-shaped bracket for the lower panel). I usually run the lights to the light switch (can't remember which terminal though, use a multimeter, I think it's the green) so it turns on/off and dims with the lights. I know it's a crash course but it's pretty easy when you look at it.
