amp remote turn on wiring on stock monsoon
I plan on installing my amp and subwoofer this weekend to my stock monsoon cd player. I have a 99 z28. I think I have a pretty good handle on the power, scosche adapter, and all the other wiring except for the amp remote turn on. Where should I get the from my head unit? Also do I have to tap into all the speaker wires from my head unit to input them to the scosche adapter or will just one speaker input will do?
Ungrounded Moderator
There is no remote turn-on wire at the stock head unit. The Monsoon amp uses signal sensing to turn on when an audio signal is detected at its input. Since Camaros don't have the power antenna wire to use as a substitute, your best bet is to use the RAP power wire - yellow wire in black connector.
You only need to tap into one set of speaker wires for your line out converter.
