Installed New Battery, Speedometer Is STUCK!
Old Jul 30, 2008 | 01:14 PM
bamxbam's Avatar
Default Installed New Battery, Speedometer Is STUCK!
Like the title says, today morning, I changed my battery on my 1999 Z28, and when I started my car afterwards, I noticed that the needle on the speedometer is stuck allll the way to the right, way past the 150mph mark... and is just resting there. I tried driving the car around for a few minutes, knocking on the clear panel of the gauge cluster (always fixed a stuck fuel gauge lol), and disconnecting a reconnecting the battery without any success. I'm puzzled as to why the hell a simple battery change would cause something like this, everything else seems to be just fine and normal except for that darn speedometer.
Old Jul 30, 2008 | 07:31 PM
wssix99's Avatar
Save the manuals!
Happens when you loose power and the needle is past half-way. The only fix is to take the cluster out of the dash, turn it up side down until the needle falls back half-way, and then rotate it until the needle falls back in place. Re-install.
