Where is the door switch located?
Old Aug 4, 2008 | 06:02 PM
ROCNDAV's Avatar
Default Where is the door switch located?
I have a 1994 Camaro. The Door switch (the switch that tells the car the doors are open, and turns on the light) was located by the door hinge (IIRC).
My 2002 Camaro SS Convertible does not have switches in this location. Did GM switch to proximity switches? or did they move them elsewhere?
Old Aug 5, 2008 | 09:10 AM
wssix99's Avatar
Save the manuals!
On the 2002, the switch is inside the door and integrated with the latch mechanism.
Old Aug 5, 2008 | 11:56 AM
ROCNDAV's Avatar
So they did move it to the door handle/latch mechanism.
THanks!
Old Aug 5, 2008 | 03:45 PM
wssix99's Avatar
Save the manuals!
I believe its all in the latch mechanism, which is bolted to the inside of the end of the door. The handle is separate and connects to the latch mechansim by a rod. (Not sure how the previous generation cars were set up.)
You can take a screwdriver and move the rocker in the end of the door that normally engages the strike bolt. Put the key in the ignition while you do this and you'll notice all of the normal beeps, lights, etc. goinig off like you would when the door closes. (You will have to pull up on the door handle to open the rocker back up so you can shut the door when you are done experimenting.)
Old Aug 5, 2008 | 06:19 PM
shaun's Avatar
on my 98 ttop car its right under the wire thing that goes between the door and the car.
its just a push in type switch.
Old Aug 5, 2008 | 07:17 PM
ROCNDAV's Avatar
Yeah, that is where it is located on my hard top 94. I thought maybe it was a convertible thing. Now that I think about it, I believe the light turns on when the handle is lifted on the 2002 convertible. I'll have to check it when I get home.
Thanks guys,
David
