HID/LIGHT Problems
Old Aug 7, 2008 | 10:17 AM
Brian2006's Avatar
You need a relay.
When you first turn on your HIDs, the ballasts require near double the power for the first 5 seconds or so, to ignite the igniter. In some cases, cars do exactly what you are explaining and can only power one headlight at startup. A relay will act as an on/off switch to power your HIDs and to also be a safety precaution for not overloading your HIDs.
The factory wiring sucks. I don't care what anyone else says
Old Aug 7, 2008 | 10:18 AM
Brian2006's Avatar
PM and I'll give you a site to purchase a relay to solve this problem.
Old Aug 7, 2008 | 10:19 AM
Pharm0r's Avatar
Originally Posted by LS1_SS
If you were having problems BEFORE then installing HID's is not going to fix the problem. If the halogen bulbs weren't working properly, the HID's aren't going to work properly.
I believe my problem before was concerning the left lowbeam connector, the wires were all chewed up and sticking out, if i messed with it a little bit the lights would come on fine. That is why i got the HIDs (well my excuse to anyway) because they do away with that connector, and the only place i could find the connector was the stealership for $80. (Cant find any fbods in the junkyards here)
Old Aug 7, 2008 | 10:22 AM
Pharm0r's Avatar
Thanks, ill keep that in mind, lemmie make sure they work first, then ill pm you for the side if they do.
Old Aug 7, 2008 | 10:28 AM
Brian2006's Avatar
Even if they do, the relay will only do good for your HIDs. It will bypass the shitty wiring and increase the life span of your HIDs
Old Aug 7, 2008 | 11:51 AM
Pharm0r's Avatar
**moved All Updates To First Post**
Also hotwired the hids to my battery, they work.
Also posted a pic in my original post
Old Aug 8, 2008 | 10:33 AM
Pharm0r's Avatar
So what yall think? Time for a relay harness? Also, I need ideas of where to tap my harness into...I'm thinking maybe the popup headlight motors, so my lights still work like stock (the lights only flip up when you turn on the lights) i cant tap into my running lights cus they are on all the time....
or what do you think the possibility of wiring a small amp between the two wires....?
ideassss i need ideas!
Old Aug 8, 2008 | 10:47 AM
2001CamaroGuy's Avatar
its simple, take a hot lead off the battery and use the stock headlight wires to operate the new relay...
http://www.cs.usm.edu/~jmneal/tiburon/hids.htm
Old Aug 8, 2008 | 12:58 PM
Brian2006's Avatar
The kit I sent you comes setup with connectors to wire it directly to the battery. No need to tap anywhere.
Old Aug 10, 2008 | 06:47 PM
Pharm0r's Avatar
welp, ordered a relay harness....ill update when it comes in!
Old Aug 10, 2008 | 07:17 PM
C Murda's Avatar
dont know if this has been mentioned but when i first set up my LEDguages HIDs i was having problems too. make sure that the ballasts are NOT mounted on anything metal IE your radiator support or anything else that is grounded. for some reason it was shorting out my lights and would make a loud irregular HID noise. also one of my lights would not work. i mounted my ballasts to the grey fiberglass panel that the front bumper is mounted to with those push pins and everyhing worked perfect and still is working 2 years strong...
Old Aug 10, 2008 | 11:28 PM
  #32
Pharm0r's Avatar
REALLY? I'll be God-damned. Both my ballasts are mounted to metal. Ill give this a try tomorrow and see how it works! Thanks for the info buddy!
Old Aug 11, 2008 | 10:10 AM
  #33
C Murda's Avatar
ya let me know if that was the problem...like i said as long as thos ballasts arent touching metal it may fix your problem... i mean i have an LED gauges kit too and for some odd reason my ballasts were shorting out when i had them mounted to the frame rails...good luck bro!
Old Aug 11, 2008 | 11:30 AM
  #34
Pharm0r's Avatar
nope, tried it today....i set the ballasts on the bumper and even let them hang free and no luck. Just waiting for my relay to get in now....
Old Aug 11, 2008 | 07:56 PM
  #35
C Murda's Avatar
well sorry to hear that and sorry if i got your hopes up... it must just be the wiring.. is this an LT1 car that the HIDs are going into?
Old Aug 11, 2008 | 08:26 PM
  #36
Pharm0r's Avatar
nope. its an ls1 (car in sig) im sure the relay will fix my problem. all the volts are fine, and the hids come on when hotwired to the batt. We'll see in a couple days.
Old Aug 13, 2008 | 01:52 PM
  #37
Pharm0r's Avatar
installed teh relay today and it works just fine! thanks everyone
Old Aug 14, 2008 | 02:22 AM
  #38
2001FireBird's Avatar
THat's Coo Pharm0r that it all worked out. I'll be installing my HID's this week and if something like this comes up I'll know what to do. Post pics also, I'd like to see how it turned out.
Old Aug 14, 2008 | 09:26 AM
  #39
Pharm0r's Avatar
put pics up on my fquick under exterior. if you end up having the same problem lemmie know and ill pm you the place to get the relay. real cool people!
Old Aug 14, 2008 | 10:10 AM
  #40
just for info, under-size/over-length wiring is a standard problem on f-bodies....
the "slow passenger's window motor" issue is a prime example.
- from day 1, my passenger's window was slow operating (just like everyone else).
- when my rebuild began, I did a 100% rewire of the car (ALL factory wire thrown out and totally rewired car with correct gauge wire)
- passenger's window now runs spot-on dead even speed with the driver's window (which even the driver's window runs faster than stock)
comparison, I installed HIDs on my 04 Silverado in both the lows AND Fogs, and upgraded the highs to 100Watt bulbs, yet they have always worked flawlessly (no relays installed or re-wire required)...
