Door speakers ratteling!
So they are just crap speakers? I never had the problem before I switched door panels.
You may be able to patch the tear with a very small piece of tape for now, but that will greatly degrade the sound quality.
i noticed when replacing my window motor, that the bar inside the door had little movement and im sure they rattle when bass is turned up, dynamat stuff would be great there
There was a failed attempt to keep the cone attached to the foam on the Firebird speaker by the owner. The foam simply deteriorated.
The other problem is that the plactic mount also has foam sandwiched between the plastic mount and is screwed to the doors which are a fiberglass like material. That foam also deteriorates significantly which then allows the plastic to come in direct contact with the door. This also allows for vibration since there is no longer anything to deaden it.
j/k.
