speaker wiring for sail panel?? - 02 transam w monsoon
Can someone let me know which wires are ground, and which are power? I just bought the bazooka replacement subs. I cant find a wiring diagram online though for dual voice coil setups. Can someone tell me which colors are the power and ground for the pass and drivers side?
thanks
thanks
Ungrounded Moderator
I don't know how I could have made it any more clear:
F2 - TAN - right rear subwoofer negative output
F3 - RED - right rear subwoofer positive output
F4 - LIGHT BLUE w/BLACK - right rear subwoofer speaker negative output
F5 - DARK GREEN - right rear subwoofer speaker positive output
E13 - WHITE - left rear subwoofer negative output
E14 - TAN - left rear subwoofer positive output
F10 - LIGHT GREEN w/BLACK - left rear subwoofer speaker negative output
F11 - DARK BLUE w/WHITE - left rear subwoofer speaker positive output
Tit is a little confusing to me.
Half of those outputs use the word "subwoofer" while the other half say "subwoofer speaker".
now I know I'm probably over complicating this, but since the sail panel subs are DVC I'm left wondering if all 8 of these wires go to the 4 coils of the subs? Or does the half that say "subwoofer speaker" refer to that little 4" driver in the hatch?
All subwoofers (and tweeters, and mids, and woofers...) are speakers so the terms "subwoofer" and "subwoofer speaker" refer to the same thing. I have edited the FAQ to remove the redundant word "speaker" for consistency.
All eight wires listed go to the sail panel subs - four to the left side and four to the right side. Every speaker voice coil has a positive and a negative connection (two wires) so a dual voice coil speaker like the sail panel subs in Firebirds (does not apply to Camaro) has four wires.
E1 - DARK GREEN - right front negative input
E2 - GRAY - left front negative input
E3 - TAN - left front positive input
E4 - DARK BLUE - right rear positive input
E5 - LIGHT BLUE - right rear negative input
E6 - YELLOW - left rear negative input
E7 - BROWN - left rear positive input
E8 - BLACK - ground
E9 - BLACK - ground
E10 - not used
E11 - ORANGE - fused input feed
E12 - ORANGE - fused input feed
E15 - DARK BLUE - left front midrange positive output
E16 - LIGHT BLUE - left front midrange negative output
F1 - LIGHT GREEN - right front positive input
F4 - LIGHT BLUE w/BLACK - right rear subwoofer negative output
F5 - DARK GREEN - right rear subwoofer positive output
F6 - DARK GREEN - right front midrange negative output
F7 - ORANGE - right front midrange positive output
F8 - not used
F9 - not used
F10 - LIGHT GREEN w/BLACK - left rear subwoofer negative output
F11 - DARK BLUE w/WHITE - left rear subwoofer positive output
F12 - not used
F13 - GRAY - right rear midrange negative output
F14 - WHITE - right rear midrange positive output
F15 - RED - left rear midrange positive output
F16 - PURPLE - left rear midrange negative output
That is a thing of beauty 👍
E8 - BLACK - ground
E9 - BLACK - ground
E10 - not used
F8 - not used
F9 - not used
F12 - not used
