wiring amp to factory head unit?
Old Sep 20, 2008 | 12:06 AM
gfeller2006's Avatar
Default wiring amp to factory head unit?
I was wondering how you wire an aftermarket amp for a sub to the factory head unit? I did a search but was unsuccessful. Any links or tips would be great.
Old Sep 20, 2008 | 12:58 AM
98boxer's Avatar
For a factory headunit you will need a part that uses a pair of speaker wires into rcas. Its about 20-30 bucks. Then you just have to find the remote wire in the factory headunit i don't know which one it is.
You can run the amp wire through the fire wall after removing the car computer there will be a gromount and just past the wire through there.
Old Sep 20, 2008 | 10:37 AM
Seanh's Avatar
Base system or blose crap?
Old Sep 22, 2008 | 08:09 AM
Its the monsoon system. Where can you run the wire through the firewall? And where can I get that part?
Old Sep 22, 2008 | 08:42 AM
KEE AUDIO's Avatar
Power wire for the amp is ran through the firewall just behind the PCM. There is a large grommet behind it.
To get a signal you use a hi/lo level converter which turns speaker level signal into low level. Some amplifiers also have speaker level inputs on them that sense when a signal is coming into the amp and use that as your remote turn on instead of having to run a seperate remote wire. This is actually how the stock Monsoon turns on.
Old Sep 22, 2008 | 11:57 AM
Where is the best place to tap in to the speaker wire at with the converter. Ive heard you can tap into it right at the stock amp somewhere? Is that true? Plus where the heck is the pcm even at on these things? Passenger side by the firewall or where? I no dumb question but please help. Do you have to take the pcm out to get to the grommet?
Old Sep 23, 2008 | 09:19 AM
98boxer's Avatar
check out my car domain link in my sig, theres pictures there on how to run amp wire
