Couple ?'s - setting up two amps
Also, i have one 4awg +12v running to the back passenger side for power, can i tap into this and run both amps off of it or does it also need another power cable? how should i go about this setup?
And lastly, i have a sirius reciever and am not sure where to mount it since its about the size of my hand
Provided the 4g wire is thick enough for the amperage draw of both amps, you would use a distribution block to split the wire between the two.
http://www.knukonceptz.com/productMa...0Fuse%20Blocks
