Monsoon cuts out.
Old Oct 7, 2008 | 11:55 PM
STSCS's Avatar
Default Monsoon cuts out.
Car is new to me. The head unit powers off on its own, tappin the left upper bezel area/ trim gets the power back. Thinking previous owner tapped into power their and now the connection or wire for power is broke or loose. Is their any tricks to pulling the radio to look for the loose wire/ connector? Any guesses?
thanks Ed
Old Oct 12, 2008 | 09:38 PM
ABJ88's Avatar
I think you have the same problem I HAD. It has to do with the BCM. I'll look for the thread then post it here for you.
Old Oct 12, 2008 | 09:43 PM
ABJ88's Avatar
I believe this is it: https://ls1tech.com/forums/showthrea...hlight=bcm+fix If you have any questions just PM me.
Old Oct 14, 2008 | 09:38 AM
Jayh's Avatar
thanks Ed
Pop the trim cover off that surrounds the deck/a/c controls....take the two screws out holding the deck in.....2 minute process......antenna wire is short......
