Help with hardwiring Valentine1
Old Sep 11, 2003 | 07:06 PM
bigMAC's Avatar
Default Help with hardwiring Valentine1
Im using the instructions from www.ls1howto.com and im having problems taping into the brown wire. I destroyed the blue tap that came with it trying to cut through the wire. Any ideas with that? I tried dikes but I had no room under there and was afraid of cutting the wire all the way through. Also where did you ground yours? I can't see where JMX grounded his it looks a lil different then mine. Thanks In Advance.
Old Sep 12, 2003 | 03:02 PM
bigMAC's Avatar
Default Re: Help with hardwiring Valentine1
Come on guys. I found out where to ground it, just tell me how you tapped into the wire. It is the biggest pain in the ***. I'm going to wind up screwing up my car because I'm the biggest retard in the world and no one will help me out.
