10 second passes - GoPro Videos
Stock motor - 86k miles
150 shot - NX Wet
QTP Headers
True Duals
FTI TH400
FTI Converter
Moser 9" narrowed 3" each side
Hoosier Drag Radials 275/50/15
BMR Suspension
(Make sure you watch the video all the way to the end. I left a surprise for you guys. You'll thank me later)
150 shot - NX Wet
QTP Headers
True Duals
FTI TH400
FTI Converter
BMR Suspension
150 shot - NX Wet
QTP Headers
3" exhaust with x pipe
True Duals
FTI TH400
FTI Converter - couldn't tell you the stall, Greg has reworked it a couple times
Moser 9" narrowed 3" each side, 3.75 gears
Hoosier Drag Radials 275/60/15
Wolfe 6 point roll bar
BMR adj lower control arms w/ relocation brackets
BMR adj panhard rod
BMR adj torque arm mounted to TH400 trans mount
BMR extreme sway bar
3480 lbs w/out driver
That's pretty much it. I shift at ~6000 rpm. lol
Any other questions, let me know.
