Cam only m6 10.86
Thanks! It was a good feeling to finally hit my goal. Now I can actually put some heads on this thing and would like to spray it. Rowing gears is just to much fun. Had 3 or so 10.90 passes and one pass pulled the wheels pretty good but when I jammed seconded it was bouncing and my foot hit the clutch pedal and kinda disengaged the clutch for a second lol so 11.0 run that time
My ls1 is cam only i was also going to spray it and be done with it, but i think im gona do heads. Some trick flow as cast 220's, and have tooley do some work on them as martin suggested. Im loving your times. What cage work are you going to get done?
Well will be done by MWC and whatever certifies to 8.50 will be good for me. Also thought about the as cast heads that are worked over. Will have to research and call ppl to find out. Whatever it be they will be well worked over any other questions ask away.
