can i make it
can i make it
i just can seem to get that 11 second pass i think the car can do it so far my best was a 12.2@118 with a 2.1 60 and a 12.4 @118 with a 2.3 60 the car is a 2000 m6 z28 with TR raptor cam, 3:73 gear LTs ory slp loudmouth... the car also has a 100 shot of nitrous but i have yet to spray because i have trac issuse as so as it is i run with a set of goodyear eagle ss drag radials and it still doesnt hook??? what do i need to hit 11s
just need more practice. I was in the same boat as you. best time was an 11.98 at 118 on a 1.81 60 ft time. I have since switched to a TH350 with a nice sized stall. Im going to the track next weekend, so we will see how it does with the auto Just get your launch down and you will have a nice 11 second pass.
thanks i guess i will just have to practice and drop the pressure more i havent tried to take the front sway bar off so iill have to do that and see what happens.. before the cams i had no problem i was cutting 1.9 60s all day no it just seems like if i dont just pull out it is spinning all of first so i peddle it and i havent seen a better 60 than a 2.1 with the cam
