11 Second Club Snake eyes are a good thing
11 Second LT1
Old 06-16-2014, 11:07 AM
Zeke28's Avatar
Default 11 Second LT1
New personal best 11.72 @ 110.00mph, (on the limiter before finish line) 1.56 60 ft., @ New England Dragway, 06-08-2014.
1984 Z28 LT1, 350 CI, TSR built turbo 350, 750 AED carb, CC502 cam, 1.6RR, Strange 12 bolt w/4:11 gears, Pro Torque 3600 converter, 1 5/8" Headman Hedders, Crane Ignition Box, Spohn Torque Arm, M/T ET Streets Drag Radial, 3030 lbs. w/driver.
Might be another tenth in it in cooler temps....
New PB's - 11.53 and 1.53 60 ft. NED 09-26-15. Same setup.
Old 06-20-2014, 03:29 PM
BODUKE's Avatar
Welcome to the 11 sec club.
Old 06-21-2014, 12:00 PM
Zeke28's Avatar
Thanks!
Old 06-23-2014, 07:25 PM
Droptopws6's Avatar
Nice 60' time
Old 06-24-2014, 08:13 PM
Zeke28's Avatar
Originally Posted by Droptopws6
Nice 60' time
Thanks!
Prior to this outing I made some rear suspension and tire pressure adjustments that really got the rear working.
I was surprised by how hard the car pulled off the starting line. My previous best 60' s were 1.70's.
Old 08-19-2014, 09:53 PM
Zeke28's Avatar
Smile
Update: 11.60 @112.1 mph 1.54 60 ft. 08-10-14 NED
Old 08-20-2014, 11:20 PM
KLaBZ28's Avatar
Car is ripping man. I go up there often let's meet up next time!
Old 08-25-2014, 08:56 PM
Zeke28's Avatar
Stop by and say hello. I run in the street points series. I TRY to make most points days. Dark blue w/gold trim third gen Z28 - ST 53.
Old 08-26-2014, 08:25 AM
Mystery Bird's Avatar
Congrats, nice to see LT1's still getting it done.
Old 08-26-2014, 08:45 AM
KLaBZ28's Avatar
I sure will. I might go up tomorrow or Friday, gotta pop the drag radials on.
Old 08-27-2014, 09:42 PM
George Goodwin's Avatar
Great 60s I'm in the points with ya and had no idea u had the mighty LT1 under the hood. I'm running the white 80 Z28. I have missed six of the races this year but will be there on Sunday. Would love to check out the car.
Old 08-28-2014, 08:53 PM
Zeke28's Avatar
Hi George. I've missed 5 or 6 points races this year too. I hope to make the race this Sunday.
See ya there!
Did you race a white 80's Impala a couple of years ago?
Old 08-29-2014, 06:55 PM
I did. The LT1 that was in white caprice is now in the Z, less the LE heads, I bought AI heads and cam after I rebuilt the bottom end. I'm still kinda babying the motor (just 300 miles on the rebuild) but leaving at 1800 and shifting at 4600 has pulled the Z to a best of 12.13. I'm hoping with the Pro Systems carb back on, leaving at 2400 and shifting at 6200 it should run a low 11
Old 08-29-2014, 09:04 PM
Zeke28's Avatar
Sounds awesome George. I've read that the AI stuff is top notch on the LT1.
Best of luck with it.
See you Sunday.
Old 09-08-2014, 04:18 AM
Dannyac500's Avatar
Nice 60'! Im right behind you, just hit 11.97 @ 113 with a 1.61 60' @ last weeks Wednesday street night!
Old 09-09-2014, 07:13 PM
Zeke28's Avatar
Congrats! Welcome to the club!
Old 09-29-2014, 05:43 AM
Did you mis yesterday? Going up Sat for Chevy vs Ford day? I looked for you yesterday to ask you what shift points are you using? I put the Holley back on and shifted a bit higher but only ran a 12.06 @ 113 I think my Trans has lazy shifts. Seems way too long from me moving that Quicksiler shifter and the shift happening.
Old 09-29-2014, 06:25 AM
scotty2000ss's Avatar
Dang, nice time! Man I need to get rid of my 10bolt lol.
Old 09-29-2014, 11:55 AM
Zeke28's Avatar
Yeah, I couldn't make it yesterday - very disappointed.
I'm going to try to make it Saturday, but the long range forecast didn't look good, 80% chance of rain.
I'm still short shifting mine a bit I think. Shifting @ 5800 rpm and hitting the rev limiter set at 6100 well before the finish line. I'm trying to save my factory stock short block and I don't want to run below 11.50, because then I'll need a roll bar.
With what I know about your setup, I think you should be shifting well above me for max performance.
If I don't make it Saturday, I'm gonna try to make a test and tune and call it done for the year.
If I don't see you, best of luck the rest of the way and see you next year.
Steve
Old 10-04-2014, 02:23 PM
RedFirehawk's Avatar
Congrats!
Quick Reply: 11 Second LT1
