11.29 @ 120.94 mph would like a yitle change.
11.29 @ 120.94 mph would like a title change.
99 228 m6 spec3, pro 5.0 shifter, 26x11.50-16 tire, 3.73 in the strange s60, sts turbo gt67,twin intercooled, running 9psi, synergy shutter shitch, launching @ 5,000 rpm under 4-5psi. qtp long tubes , custom exhaust & intake plumming. the car consistantly runs 11.29. the time slip i have in front of me is as follows08/03/207 .078 reaction, 1.6338 60ft., 6.789 -594ft. 7.254 1/8,95.88mph 1/8, 11.292 1/4, 120.94 mph 1/4. at oceola drag way in oceola indiana. i ran several mid 11 pass's over a 3 week period untill they busted me for no cage. i can run there again after i install a cage. cant blame them. saftey first. thanx for considering my title change.
thanx. i am learning the hard way to shift. i think it would run high tens if i had some one that can shift behind the wheel! lol. at least i have fun jammin it in gear lol.
mph seems to be way off. i dynoed 424hp and ran 11.36@121 and you have way more hp&tq than me. The da when i ran was around 1800ft. do you think there's something wrong in your tune? with 533hp you should be trapping 130 with a stick car.
no the tune is solid. i am still spinning off the line & i have 3:73 gear wich is hurting the boost a bit in 1st gear. take in mind i have a stock long block & cam. i am a terrible shifter as well. i am a builder. i dont claim to be a driver. lol Thanx wiplash. i will repost
E.T.'s are bragging rights, not dyno #'s
I think your times are great. With room for improvement of coarse.
Your also not in an M6 either WHPLASH, i ran 11.74@114 in my A4/3.73gears,...I think it would be correct and equivalent for me to run 11.3@121, but only b/c I dont have the top end that a M6 and/or FI car has. My solution is that you need to throw a turbo cam in that car.
i agree with the turbo cam for sure. but as you guys know running the stock moter under these condition even though i am rich in fuel & adding meth. soon. it wont handle it for long. so i am waiting till i beef up the bottom end & at that point i will do heads intake & turbo cam. i still have the sock intake & t-body also. no emisions. the only thing i have done is valve spring & 2-bar s.d.
