12 Second Club In the 12s yet? Come inside!
am i capable of a high 12?
Old 05-24-2007, 07:34 PM
Ls1fortheWin's Avatar
Default am i capable of a high 12?
i have a 98 z28 a4. my mods list includes slp flowpac, tci streetfighter trans with 2200 stall, 3.42 gears, slp lm1 catback, slp maf, sphon adj. torque arm, and a set of bfg drag radials 275/60/15 on welds. i also have eibach prokit with bilstiens i need the relocation brackets. my best run was a 13.5 at 101 with out the drag tires, torque arm, and trans
Old 05-24-2007, 07:47 PM
blk/slvr02ss's Avatar
i had a 98 z28 a4 with lid, no cats, flowmaster muffler,nitto 555 and ran a 13.19@106.i see no problem for high 12's with your set up.
Old 05-24-2007, 09:43 PM
spy2520's Avatar
its possible, the springs might hold you back, but i ran 12.9 on street tires, the biggest factor most likely being the stall...
Old 05-28-2007, 05:28 PM
ncarlson's Avatar
i ran 13.45 @103 2 wks ago < 98 ls1 a4 3.23 > just put in yank 3200 stall hope to hit 12s<12.6-12.7>other than that car is all stock <94000 miles>
Old 06-23-2007, 12:54 PM
i am having installed ls6 intake, jet hot lts and ory, took off all emissions and had it dyno tuned by fbody central. i was told to expect about a 12.80 what do you all think.
Old 06-23-2007, 02:09 PM
ls1mastermind's Avatar
ya you should be doing real good i went 12.90 @107 with lid,cat delete,cutoff,shorty headers,on street tires...so you be able to do 12.60-12.80....
Old 06-23-2007, 09:52 PM
Havok2's Avatar
if stall was a 3400-3800 i think you would be there already
Old 06-24-2007, 07:19 PM
donkey mule's Avatar
Like everyone else says more stall would help. You could always put a nice shot of nitrous on there.
Old 06-25-2007, 11:58 PM
i plan on installing a 3000 to 3200 stall. i want to keep the stall small because i drive the car everyday. it has to be streetable. i have not ran the car since it was nearly stock. i should get the car back tuesday evening. i plan on breaking the new parts in for a few miles and then going to the track friday. tthe guys at fbc told me to expect 12.70s. i cant wait to be in the 12 second club. i'll keep you all posted. Also if i did run 12.70s how much more could i expect with a 3000 stall.
Old 06-27-2007, 05:26 PM
JUSTONY's Avatar
The eibach spring would decrease his time????
Old 06-27-2007, 09:42 PM
5_02ls1's Avatar
yep^^^^lowering a car with stiff springsmakes it harder to hook....how is that converter???is it looser than stock anyat all....
I used that same converter in a 5liter fox i had once and it barely compensated for the cam i was using....on spray it worked well though....
In good air id say you will bust 12s wide open....
good luck....
Old 06-27-2007, 11:01 PM
got the car back today. it dynoed at 308hp and 318tq with a baseline with new parts installed before tune was 283hp at the wheels. not bad. the car feels like a hole new car. you can feel a huge difference mainly in the top end power. the car had a lot of dead spots now it is smooth throughout. once it hits mid 2nd gear and thru 3rd it is a rocket. i am very impressed and very satisfied. cant wait to go racin friday.
You can feel a difference in the converter over stock but not much. i put an order in for a 3200 stall.
Old 06-28-2007, 08:31 PM
aggie-chase's Avatar
The modding virus infects yet another!!! Have fun!
Quick Reply: am i capable of a high 12?
