12 Second Club In the 12s yet? Come inside!
12.5 but still dissapointed.. 1.75 60 ft time.
Old 08-21-2007, 07:59 AM
shocker45's Avatar
Default 12.5 but still dissapointed.. 1.75 60 ft time.
well i went to the track, last year i was running 12.86's @ 110.4 mph,
since then i put the 9" in with 4.11's and drag radials. torque arm etc.
well, i was hoping for a deep 12 run, now the track temp was cold, and my clutch was stock. so it was holding me back, i ordered a spec stage 3+ clutch.
think with a good bite i can run a 12.20? 1.75 was with bfg drag radials, but any quicker i would break loose. so i am hoping for a sunny day next time for some more track temperature.
id like to see a sub 1.69 60 ft time. at 12.50 @ 112 i launched only at 3800 rpm, and my motor bogged down after the dump. so i need it to stick from like 5000+
Old 08-21-2007, 09:57 PM
oner's Avatar
Your stock clutch is definetly holding you back. Put on that spec clutch, with some sticky tires and dump the clutch @ 5k...you should be in the 11's.
Old 08-21-2007, 10:23 PM
95 Z28's Avatar
That trap seems a little low for 407hp...was the clutch slipping a lot?
Old 08-21-2007, 10:51 PM
shocker45's Avatar
in the higher gears it didnt seem to bad. my tires are only 25.4" tall, with 4.11 gears. i thought the trap was pretty decent.
but regardless i might be ordering a set of et streets that are 26.5" tall, so that will definately help out my trap and with sticking off the line.
how do you think it would effect my e\t? going with the taller tire?
and new clutch was ordered today, Spec Stage 3+ should have it in next week.
Old 08-22-2007, 10:41 AM
ExTurbo's Avatar
yea id say MPH is down, i was running 12.30's at 113 with just boltons, gears, and slicks in the goat. id say the 9" is robbing some power, but im sure the clutch isnt holding up as well as you'd like it to. what altitude are you running at? that could reall effect the cars performance
Old 08-22-2007, 10:43 AM
shocker45's Avatar
altitude isnt an issue. i think im at 800 ft ish.
the 9" wouldnt rob that much, im going to get taller tires, and a new clutch and then see where im at.
Old 08-22-2007, 10:58 AM
allngn_c5's Avatar
Awesome 60 time. I can only hope my Nitto Drag Extremes hook like that. You bogged at a 3800 launch, I am going to try a 4000 launch and then adjust up or down from there. GOOD LUCK !!
Old 08-22-2007, 08:01 PM
MUSTANGBRKR02's Avatar
Good times you should get there! More tuning time. I ran a 12.4 @117 last saturday stock a4 vert shooting a 100 hit and i was rich. The MT ET's weren't hooking for crap. Those BFG's doing ok for you?
Old 08-22-2007, 10:24 PM
00PewterSS's Avatar
When I replaced my stock cluck to a Spec 3 I picked up .3 from a 13.2 to a 12.9.
I put a cam in this year and have only went to the track once and my car wouldn't go into 4th gear. With a slow 3-4 shift I ran 12.5@116. That is with a 26" BFG drag radial, a bad track and 2.0 60'.
So my pt is your trap speed seems low, possibly the clutch slipping. I think both of our cars are just barely capable of 11's if everything goes perfectly.
Brian
Old 08-22-2007, 10:29 PM
Local-heretic's Avatar
Good luck hooking with the Nittos. I got them and have to heat em real good (5-7 second burnout) to get anything DECENT... Going with M/T's soon.
Old 08-22-2007, 11:09 PM
shocker45's Avatar
the bfg's are a great street tire, im very happy. but how often are you launching on the street. i just like em cuz they stick in 2nd for the most part.
at the track, very disapointed. i ordered my m\t et streets today, and am very exciting to see what a real tire is capable of.
Old 08-23-2007, 06:40 PM
you have to warm the MT's for longer than that.
Quick Reply: 12.5 but still dissapointed.. 1.75 60 ft time.
