Advanced Engineering Tech For the more hardcore LS1TECH residents
Correct way to obtain IVC
Old 10-17-2006, 01:16 AM
Beast96Z's Avatar
Default Correct way to obtain IVC
Let's say that a givin intake tract loved a 47* IVC @ .050". We have a few diffrent ways of changing IVC, such as duration, LSA, and IVC, but more importantly, which of these ways would make the most logical way of getting to 47*? If I have a bigger N/A motor, should I run a smaller duration cam and no advance to get the IVC were it needs to be, thus leaving me on the intake biased side of TDC, or run bigger duration and advance the cam to get the IVC, thus leaving me exaust biased of TDC, but a bigger duration. Being intake biased should have a better effect on a N/A application, but since I lowered my duration to get there, did I loose HP over the bigger duration/advanced cam? I guess in a nut shell, I'm asking does adding duration out weigh intake or exaust biased ICL's? What about adding duration and getting further away from the intakes "sweet spot" IVC? Can the added duration overpower the sweet spot?
The reason I ask, is because alot of people here run alot of diffrent sized cams with the same intake. Durations and ICL's can range from stock to extreme, HP can to. I've seen IVC's out of the sweet spot of these intakes make huge power, and I've seen cams in the sweet spot make big power. Just something I was pondering in my head.....
Old 10-17-2006, 09:41 AM
Adrenaline_Z's Avatar
I don't know the process of custom grinding lobes, but I would think you can
spec a lobe to be ground with your ideal IVC and not change the lobe separation.
Not too sure about your description of valve timing here, but based on what
I'm reading:
I think moving the overlap region more on the exhaust side of TDC is going
to totally kill the engine's ability to scavenge the chamber. It may end up
pulling exhaust gas back into the chamber during lower to mid range RPM
as the piston begins the intake stroke. The exhaust valve should begin to
close fairly soon after TDC to allow the intake charge to be drawn in.
I would suggest selecting some cam profiles to clarify the question.
List the valve events, along with ICL to make your statement. Maybe link
a few cam cards. That would probably help everyone answer your needs.
Old 10-17-2006, 11:54 AM
Beast96Z's Avatar
Your right, that is kind of a word jumble to get through. I'll put it like this:
Cam 1. 230* at .050" with a 112LSA/112ICL = IVC of 47*
Cam 2. 236* at .050" with a 112LSA/108ICL = IVC of 47*
Cam 3. 252* at .050" with a 112LSA/112ICL = IVC of 58*
Cam 1 is in the intakes sweet spot and is intake biased.
Cam 2 is in the intakes sweet spot, but bigger on duration, and exaust biased.
Cam 3 is completly out of the intakes sweet spot, but intake biased, why do they still make power?
Is there a point when adding duration outweighs maintaining a correct IVC? At which point does advance become intake or exaust biased? I'd like to get a good understanding of getting the IVC in the correct way, then I'll move on to EVO.
Old 10-17-2006, 12:28 PM
Many things to consider here, and a short list would be:
- lobe shape
- other valve timing events
- other engine parts
- which RPM range and Peak is to be tuned?
If everything is truly optimized for this motor at a specific RPM range, then
changing any of the above items will result in a decrease of averge power
and/or peak RPM.
Typically, a cam designed with more duration and later IVC will help make power
at higher RPM.
As RPM increases, the time that the valves stay open decreases. If the cam
allows for the valves to stay open longer at a higher RPM, there is more time for air to
enter the cylinder.
If the valve timing continues to work with all the pulses and engine parts, the
added duration benefits the horsepower curve. There will likely be a loss in
lower range power (in a non variable timed valvetrain), and/or a shift in torque
peak (higher up the band) as a trade off.
IVC is RPM dependent. Later closing IVC's work better at high RPM. COuple that
with more duration, more overlap, SCR, etc. and you're tuning toward higher RPM
power.
Keep in mind, this only works if the other engine parts can flow well enough
to support the valve timing and the engine is built to spin at higher revolutions.
Old 10-17-2006, 01:05 PM
gun5l1ng3r's Avatar
Is this generally because there will be more duration as well, or does the actual valve closing later in the stroke advantagous at higher RPMs?
Old 10-17-2006, 04:18 PM
Is this generally because there will be more duration as well...
In a case where a later IVC point allows for more duration, then generally yes.
In a case where the same lobe is put on a wider LSA, keeping a similar duration, then it's tough to call because overlap changes and then centerline
may also change.
If the later closing valve allows for more charge to enter the cylinder before
the pressure changes cause the charge to push out, then all is well.
The RPM, or mutliple RPM (harmonics) at which this occurs is based on how the pulses are
moving, how long of a period (time) is required to revert the pulse (inertia),
incoming mixture velocity (force).
Typically as piston speed increases, so does the incoming intake charge.
This can help overcome slight opposing pressure changes ABDC which allows
IVC to occur later as RPM increases.
Again, there's always a trade off. With a weak incoming pulse at 2000 RPM,
a late IVC is going to cause some of the charge to push out and reduce VE.
Old 10-19-2006, 11:29 AM
gun5l1ng3r's Avatar
Can the charge continue to fill the cylinder while the piston is on its way to TDC?
I bet that the answer has to do with the speed of the incoming charge and that piston velocity (a highly debated topic lately) has a lot to do with the velocity of that incoming charge.
Old 10-19-2006, 11:53 AM
Yes, to a certain degree (pun intended). Once piston alters the pressure in the cylinder, it's a matter of time before the charge gets pushed out.
That point in time is going to be different at every RPM, under different loads,
different intake and head combos.
It's the engine tuner's job to select an IVC that traps the most charge at
over a range of RPM that works best with the vehice application.
Sure does. Which ever force is larger is going to win the battle. The tidal
wave will always kill the small ripple in the pond when the peaks meet. Only
a tinysliver of amplitude would be subtracted from the tidal wave.
Old 10-19-2006, 12:01 PM
NoGamesLS1's Avatar
What is IVC short for?
Old 10-19-2006, 12:55 PM
SideStep's Avatar
Intake Valve Closing...
Quick Reply: Correct way to obtain IVC
