Sponsored by: DashLynx
formula
Old 10-12-2008, 10:30 AM
blackbirdls1's Avatar
Default formula
If anyone has a formula with 315s on the back can you please post some pics, thank you
Old 10-12-2008, 11:14 AM
Spd-Kilz's Avatar
This is the only picture that I have.
Old 10-12-2008, 12:40 PM
Did you have to mend the wall or do any fabrication to fit them, if you could get better pictures when you get a chance, that would be great
Old 10-12-2008, 01:08 PM
RAMPANT's Avatar
Here is my street set up with 315 Nittos on 10.5" rims:
This is 315 Kuhmo V710s on ZR1 with a custom 40mm offset on the rear:
Mods I made are rolled fenders, adjustable panard rod to center the diff, very light BFH mods and I shaved the bump stops about 1/8".
Spd-Kilz's Avatar
It's not my car, but my guess is that all he had to do was the BFH mod, and roll his fenders (if it's lowered).
Hope this helps.
Old 10-12-2008, 02:05 PM
car would be stock height, and just the replica zr1s i believe, no custom offsets.
Old 10-12-2008, 02:09 PM
02gtp4now's Avatar
you will be fine at stock height
Old 10-12-2008, 02:24 PM
RAMPANT's Avatar
A real ZR1 offset is a little too much at 36mm, I had 4mm milled off them. The 55mm GS offset is fine on the outer fender but needs some BFH(Big F'n Hammer) inner fender mods and you should likely cut the bump stops off or when the suspension completle unloads it will hit the inside of the rim.
Mine is not a stock ride height, but is only lowered about 3/4" with the Ground Control kit.
Old 10-12-2008, 05:53 PM
BlueBird346's Avatar
Sumitomos
