pop up light motor going out
is it making a crazy grinding noise when you close the lights? thats a sign of a stripped gear. if its anything like the TA lights, you can take out the gear and turn it 180 degrees, re-install it and it will wokr fine since only 180 degrees of it are used to flip the lights.
Well, that is partially right but sort of majorly wrong. That is like removing your engine to change the air filter...
You don't need to remove the gear. You just unbolt the arm it is attached to, spin it manually and reinstall... Same end effect.
