Sponsored by: DashLynx
Turndown on a Cutout
Old 01-13-2009, 12:08 PM
the_merv's Avatar
Default Turndown on a Cutout
I know that this isn't something that you can normally see, but something that I'm doing.
I'm doing it becuase my car ran a tad rich and it blew soot all over the underside of the car and covered the Suspension and all of the area around the Cutout pretty much in soot. I'm also re-doing how the Cutout pipe is welded on to the Exhaust because the Muffler Shop that I went to to do it couldn't get the angle for it tight enough while it was on the Car, so now that it's off the Car I'm going to fix it and make it better.
I have a QT 3.5" Electric Cutout bolted on the car with a 3-Bolt Flange, so what I'm doing is taking a 3.5" 3-Bolt Flange & a 3.5" Turndown that I bought on Summit, and basically making a bolt-on Turndown.
This is what I bought..
I'm not using the whole Turndown, I'm cutting it to where it fits good and has a nice angle to it, but I'm trying to get it pointed down pretty much. Then bolting it on with the Electric Cutout inbetween the Flanges.
Any of you do anything like this?
Old 01-13-2009, 12:40 PM
drummydummy's Avatar
Sounds like a good idea!
Post up some pictures when you're finished. Havn't seen this much, if at all before.
Old 01-13-2009, 12:47 PM
TORCHD 02 TA's Avatar
That is what i am going to do when i get my cutout welded in the spring time
Old 01-13-2009, 01:32 PM
Nick_Rapitis's Avatar
sounds like a good idea...i;ve been thinkin about getting a cut-out but dont know if it will make a difference with my slp loudmouth set up
Old 01-13-2009, 01:37 PM
bobbyd's Avatar
post some pics when you have it done.
im interested in doing this
i also have a e-cutout like you
Old 01-13-2009, 01:38 PM
ALLMOTOR346CI's Avatar
I gained 3mph with my cutout even with the lm1 exhaust im basicaly running an open y pipe......
Old 01-13-2009, 01:40 PM
AChotrod's Avatar
Its a great Idea!!! I just saw a pic on here yesterday of that set up!!
Old 01-13-2009, 01:50 PM
bobbyd's Avatar
can you post it? or do you have a link?
Old 01-13-2009, 01:55 PM
what about sound? what all do you have done to your car? im still run the stock headers/manifolds...does that matter?
Old 01-13-2009, 01:57 PM
bobbyd's Avatar
it should also have a deeper sound since the sound will now bouncing/hitting the floor right?
Old 01-13-2009, 02:01 PM
i didint think it would do much with the lm1 since its basically straight pipe and no muffler...but im by no means an expert when it comes to this stuff
Old 01-13-2009, 02:34 PM
the_merv's Avatar
Here is a pic that was posted by one of the guys, he was unsure of who's car it was..
This is pretty much what I want to do.
Old 01-13-2009, 02:38 PM
how is that gonna work with the e-cut-out
Old 01-13-2009, 02:44 PM
Joshiedoom's Avatar
Subscribed
Old 01-13-2009, 03:00 PM
the_merv's Avatar
Easily. The Cutout is going to go inbetween the Flanges, and it will clear everything without a problem. All I'm doing is putting a turn down on it. I still can open it and close it in the car without a problem.
Old 01-13-2009, 03:03 PM
crossroads's Avatar
I like that idea....waiting to see how merv's come out
Old 01-13-2009, 03:05 PM
the_merv's Avatar
Yea, you guys know me, I turn out some good stuff..
Old 01-13-2009, 05:03 PM
pace's Avatar
The badlanz e-cutouts have something similar to that. But it's easy enough to do it yourself or have a shop do it for the price.
Old 01-13-2009, 05:29 PM
Spd-Kilz's Avatar
Merv:
I did exactly this. It works perfectly. Welded the turndown (which was cut), and welded it to the 3-bolt flange.
BUT
It was installed onto a Flowtech cutout. It worked perfectly, until I put my DMH cutout on.
The combined thickness of the turndown and the DMH unit was too much for the bolts on the flowtech cutout, so I wasn't able to use it once the electric dump was put on.
I can grab some pictures of the turndown when I get home.
Old 01-13-2009, 05:51 PM
Spd-Kilz's Avatar
Here you can see the bolts are just barely long enough for the DMH unit itself.
Quick Reply: Turndown on a Cutout
